Wardview, LA | So on my Rogator 664 basically the same as a 854, when I run down the road or stop spraying, the sprayer will not go forward or back ward until I throttle down and let it sit for a little bit. Sometimes I can cheat it by throttling down and engaging the 4wd & traction control, I blew a main hydraulic line last year and I know there is some type of debris on one of the pressure relief/check valves that is causing it. I runs well except for this. Anyone now where to start in lieu of pulling all of them and cleaning? | |
