NESD | I know on the brown box in the cab I can manually press E to turn the main clutch on or off. I would like to add an external foot switch or in the future possibly even use a coverage map on another display to turn main clutch on or off. Is it possible to add in the cab to brown box harness or do I have to somehow tie into the implement height switch? Ours has a potentiometer for the height switch so I'm not sure how this would be accomplished. I was reading in the book about limp home mode that uses a jumper on the cart to manually turn on main clutch. Thinking I could install switch here if nothing else. Any info greatly appreciated! Currently use a brown box with implement harness through back window to control cart, and 2600 in greenstar ready cab for steering. | |
