C KS | This page has 60 amp relays that might help you: http://www.wiringproducts.com (look for automotive relays). The relay pulls very little amps so this should be immaterial to the amperage the ez can handle. You want a 5 terminal relay so you have a normally on pole. When the relay gets power from the ez boom it breaks the circuit and thus letting down the drill. This is done using the 87a pole and the input pole. Here is a diagram: http://www.rattlebars.com/avalanche/relay_basics.html . I don't know how much about relays you know or if this will work but it is a place to start.
JRW
Edited by Farmin' Fireman 3/22/2009 20:50
