NE Indiana | As for taking a long time to do anything I would manually delete the jobs and also run the job blanker software. It also sounds like your touchscreen is going out you can try to calibrate the touchscreen to see if it gets better or may have to send to Ag Express to have it replaced. I believe that to calibrate the touchscreen is that you touch the screen when the Raven backsplash pops up when you first power on the console (I could be wrong its been a while since I've used a Cruizer II) and follow the instructions on the screen. One thing I noticed from my times using the Cruizer is that it doesn't seem to have a lot of capacity to hold jobs so I put a USB into the side and had the Cruizer save the jobs to that instead of taking memory space up on the console | |
