| It will work, but you will be taking a chance on the price of a valve, cables, steering position sensor, 600 lightbar and the engage switch. Lightbars are available used. There should be used old style valves sitting on shelves. I traded in 3 of the short versions for the long pwm box and will soon try an aftermarket PWM proportional valve (about 1/5 the cost of the Raven valve) with one of mine. If it works, I will have some of the old style valves (load sense type) on my shelf. If you need much dealer support, it might not be there. | |
