SCNE | If you are going from the receiver on the front of the cab down into the cab, you will need to remove the cab roof. The cable emerges in the front of the cab through the hole for the windsheild wiper. It then goes along the front of the cab over to the right side, back along the right side to the right rear cab post. The cab post interior needs to be removed and the harness is routed down the cab post and then under the right side console/gauges. The two displays on the console come right out by removing a couple screws so you have access to the "guts" behind the console. The harness continues under the console to the front of the cab and then up the right front cab post to a conveinent height to connect to your particular display. It works best to pull the receiver end from under the right side console, up the cab post, out the small hole in the top of the cab post/roof, and then out to the front of the tractor. There is a small "pigtale" with a cap on it about a foot from the receiver end and the size can be reduced for pulling by removing that cap. You can put it back on when you are done pulling the harness out where you need it. Clear as mud? Hope that helps. My harness came with a diagram, and although not the best, it did help a little. | |
