| Vac or Finger pick up? It is a vac, then the brackets that hold the vac tube up above the frame work well. I just mount the plates to those. Usually on one of the wings by the braces that run at an angle to the front end when folded out in planting position, so then one CAN bus pwer ext. will get you to the back of the tractor. This position works well for the clutch & seed tube mointoring. I have not done any rawson stuff so I don't know if those cables will require you to stay X ft. from the drive. Hope this helps and makes sense. | |
