Posted 3/18/2009 00:20 (#648050 - in reply to #647696) Subject: Re: JD 7200 hydraulic problems-help!
sc kansas
that is the correct way to run on 50 series tractors so when you turn off the hrd motor it will freewill as it slows down, and the 4050 has closed center hyd also.
