Elkmont, AL | Wanting to add a monitor mounting bar between the A post and B post on the console side of the cab. I would like to drill and tap a hole in the posts to mount the bar on. Is there any lines run inside the tubing of the A and B post I need to be aware of? I looked and it appears the air condidtioner lines are on the door side of the cab, and I also found a wiring harness on the outside of the A post behind the plastic post cover, that I can go around no problem. Just wanted to ask before I made a major screw up and drilled through a line or wire. Thanks | |
