sleepy hollow , wi | I CALLED QLF THE COMPANY REP SAID THE DAYTON PUMP WE ARE USING IS A DECENT ONE AND SHAFTS BREAK IF NOT GREASED REGULARLY . IT WAS GREASED JUST MAYBE NOT ENOUGH . I PRESSED OLD SHAFT OUT OF GEAR YESTERDAY ,TOOK IT TO LOCAL MACHINIST. HE THINKS HE CAN MAKE IT . IF IT DOESNT WORK OUT ,HOW MUCH ARE YOU ASKING FOR PUMP AND WHAT WOULD BE INCLUDED I SEE DULTMEIER SELLS PUMP ONLY BUT ITS 600 PLUS .IT MAY BE WELL WORTH IT TO NOT HAVE TO DEAL WITH THIS 2X A YEAR . I WAS WONDERING IF AN OLD BEAT UP HYDRAULIC GEAR PUMP I HAVE WOULD WORK FOR THIS ALSO OR MORE HEADACHES THAN ITS WORTH #IS 920 THREE 04 0165 IF YOU WANT TO SEND PICS . THANKS | |
