Ladoga, IN, United States, North America, Earth | If it is just a simple 12 on 12 off selenoid, it should be possible. You will just have to find out which way the planter is wired to operate, whether it is 12 on to plant or 12 off to plant. Normally it is 12 off to plant, so you would need to use a relay to invert the output of the ez-boom so that when the ez-boom is outputting 12 volts, it holds the relay open so that it isn't sending 12 volts to planter, and then when it the ez-boom shuts off a section the relay will close and allow 12 volts through to the planter selenoid to shut the clutch off.
You will have to find a wiring harness to plug in the back of the ez-boom. You will also be able to wire in an implement switch.
Tru-count sells an inverter box to do this. It is $120. |
