Posted 3/10/2009 22:49 (#639547 - in reply to #639540) Subject: Re: Half width disconnect value control
Breckenridge, Michigan
One might ask why I'm worried about adjusting rate on a ground driven piston pump. First, I want to read actual gpa applied, not just read a psi gauge. Not the most accurate way in my opinion. Secondly, if I should decide to change the rate applied, I could do that from the cab. In the case of test plots or in custom application where they desire a different rate.
