Posted 3/8/2009 23:29 (#636804 - in reply to #636536) Subject: RE: hyd master-slave questions
Ya, the cih engineers pulled another fup. The wing cylinders are hooked to the lift bean in a different location to change the ratio between the cylinders length and the amount of lift. That way they can use all four cylinders of the same size.
They are re-phasing cylinders and should stay that way if you are only going to replace one.
