Posted 2/25/2009 23:05 (#623143 - in reply to #622608) Subject: RE: That's great, here's more info...
Elmira, Ontario
One common error I see is blank lines in the Excel data. There should not be any blanks between the headings and the rest of the data. If you are using a named range (if you don't know what that is, you're probably not using one), the headings can be on any row, but you will probably get the best results if your headings are on row 1.
