Greenwood, MS | Since your card is full, I would not use your RCD folder that you copied from the cord as it would be full already as well. Since you said you put information in Operation Center just use the set up builder to send your information back. Be sure to select everything that you will be using in the field as it can not be added from display. When you begin select tillage, seeding, application and harvest if plan on doing all of that. You will also have to add all equipment as well. Under field selection be sure to check to make sure that boundaries and guidance lines are checked above field box. When you create the file select 2600. You will then have to go to my files and download that setup file. Once downloaded you will extract that to the card. Then everything will be there. | |
