Butterfield, MN | Unfortunately, the Cruizer II won't do what you're looking for, since the files from it can't be uploaded to Slingshot. The least expensive way I could see to do this would be to find a used Envizio Pro and add an AccuBoom kit for that machine. I believe the kit would be a 117-1004-042 along with the 063-0172-316 node, as well as any cabling you wouldn't get along with the Envizio Pro. You would want to serially connect to the 460 to get your rate information logged, as well. | |
