Posted 7/1/2019 07:01 (#7591230 - in reply to #7589842) Subject: RE: Case mxu hyd repair
you want to replace pump or fix pump? i have a salvage mxu 130 has a good pump. steering or lift? replacing its not a bad job remove rh rear tire then you can get to it easy. 507 421 0213.
