Posted 6/12/2019 17:23 (#7555379 - in reply to #7555207) Subject: RE: Bulk tank Diesel fuel nozzle troubles
There should be a small hole near the end of the nozzle that gets plugged up with junk. Sometimes you can clear it with a small flat baled screwdriver, i have had good luck blowing brake clean into this hole and then blow the junk out with air hose.
