Coles County, Illinois | My sprayer has spray balls mounted in the top of the tank. After spraying out the main tank I switch to a clear water rinse tank and run clear water thru all the circuits and then thru the spray balls. It's an 80 gallon tank and I pull about 25 gallons out, spray that out and repeat two more times. I've never seen damage switching to other chemistries after doing this but I only spray group 4 chemicals in the late fall or early spring. | |
