Search Forums | Classifieds (202) | Skins | Language
Master switch wiring on Rogator to AgLeader
LakeView
Posted 6/12/2019 09:23 (#7554775)
Subject: Master switch wiring on Rogator to AgLeader
SE Iowa
Has anyone successfully wired the floor pump switch on a Rogator sprayer into the AgLeader Direct command so you only have to use 1 switch? Currently using the floor switch and then have to turn on the master switch on the switchbox for mapping. It would be nice to tap into the floor switch so we can bypass using the toggle master switch. Anybody tried it?
