Southern Illinois | This is a horrible picture but the machine and book are at the shop I can get a clearer one if you need to but if I’m reading this correctly it should be relay 47 labeled forward front shift relay I believe it’s been 6 years so I’m not 100% sure but pretty sure if that doesn’t try it you may swap relay 43 as it’s labeled forward relay. Mine was a similar the mechanic told me them relays have been in there for awhile so there probably weak. I’ve also had issues with the lights which was a relay so hopefully that’s all yours is also.
(24BD4475-E8EB-4960-B588-33DEFCDFA9E8 (full).png)
Attachments ---------------- 24BD4475-E8EB-4960-B588-33DEFCDFA9E8 (full).png (80KB - 17 downloads)
