NW Iowa | Thank you for inputs so far.
To explain the vac motor hydraulic plumbing,
Pressure hose comes out of tractor and goes to input of metering valves on front of tongue of planter. The one hose is tee'd into both blocks with the adjustment knobs. Comes out of each adjustment blocks and each one goes in to each vac motor. One hose comes out of each vac motor and goes back up to hydraulic outlet on tractor where they are tee'd back together before going to a regular iso tip and plugs back into tractor.
I was going to use the tractor to adjust vac pressure as that is what we have done with our kinze planters as well.
Thanks again so far!!!
Edited by casemagnum 6/4/2019 20:44
