south texas | Stx450. Had a possible simular issue as u do. Need to figure out if time running is triggering the failure or if its movement of something. After days of me trying stuff i finally found that a hard right turn would trigger the faults. It was all different faults all the time. Now i could make it happen every time i wanted. Case dealership came out 2 times and found nothing. All term were replaced and diagnostics were done with no success. Tech told me he checked the clamps that hold harness and all was good. Said on down from engine was bad about tearing harness but mine was good. I had nothing to lose so i started yanking on wire harness to see if i could fault system. Sure enough when i pulled engine harness it faulted. The clamp wore through the net type wrap and was grounding out a 10ga or so red wire. I also had the alt light on on post for years. Repairing this fixed everything. Just my experience | |
- Stx425 trans, engine, pto, and armrest consol faults - duramaxpuller : 5/24/2019 19:33
- RE: Stx425 trans, engine, pto, and armrest consol faults - 1999 : 5/24/2019 19:46
- RE: Stx425 trans, engine, pto, and armrest consol faults - Drfixit2 : 5/24/2019 21:22
- RE: Stx425 trans, engine, pto, and armrest consol faults - duramaxpuller : 5/25/2019 01:13
- RE: Stx425 trans, engine, pto, and armrest consol faults - coastalBend : 5/25/2019 09:34
