Posted 5/22/2019 18:44 (#7513623 - in reply to #7513554) Subject: RE: Looking for an alternative hay crop to plant instead of corn
15ft work just the same. We would run 2 20footers at a time. I think it improves quality of coarse hay like sorghum. We used model 700 John deere hydraulic rake. It picked up every blade of forage. I wouldn't recommend using Bush hog on grass hay because it's not going to cut very good. However, if its rough ground that you don't won't to run your good cutter over then I'd still do it. We only used it on sorghums.
