Jefferson, SD | Traded my pro600 for a pro700 this spring. I had the CIH tech adjust the autosteer sensitivity a few years back so it didn't kick out so easy when you hit a rough patch etc. It appears my nav defaulted back to the original setting either with the software update or the switch to the pro700.
My question is, can I do this adjustment myself on the pro700 or does it require the CIH tech to plug in? | |
