Posted 5/14/2019 17:13 (#7497252 - in reply to #7497016) Subject: RE: JD 6d ac problem
Whitehouse
As you already figured out the resistor pack is toast. Easy to access and change, however there are also updated fans that draw less amperage and a new more robust resistor pack. If you do not update both to the newest available part numbers, you will be changing them again.
