Search Forums | Classifieds (108) | Skins | Language
Pump loosing prime on spra coupe 3640?
Tnfarmer
Posted 5/12/2019 08:06 (#7492399)
Subject: Pump loosing prime on spra coupe 3640?
tennessee
So I can spray a tank out and go fill up again and sometimes the pump acts like it's lost prime. When I turn boom valve on I have very little flow or none to the booms. If I shut off the 2 outside booms and turn on the smaller center boom it will build pressure and then I can turn on other booms and it's fine after that. This is a new hypro pump. Sprayed only about 500 ac with it. Anybody else have this and what could be happening? By the way, when I have the booms off, the pump will always work to agitate.
