Carter Montana | I worked with wheat for a number of years. It helps a lot to have good yield maps to overlay on that map, say a multiple years analysis (maybe 4 years) of normalized data, and do a correlation analysis. I might have the formula in sms if you are interested
I consistently found negative correlations ie the greener areas did relatively less well, so would be interested to see if yours is similar.
Either way, if you have some yield history I would start there. | |
