Posted 5/7/2019 08:22 (#7481227 - in reply to #7480820) Subject: RE: Integra import
Have you Set Field Boundary on the new field Boundary in SMS? You also need to go to device export and select the fields to export. Make sure you check the Export Field Boundaries Box. When you export to display select .agdata that corresponds with the firmware running on the integra.
