| That should be using the ISO liquid control with a SteerCommand and GPS6500 unless a different Ag Leader autoguidance system was put on. If there was an update to the 6500 receiver, you will need to go into the receiver settings and make sure at minimum that GGA and VTG are checked and set to 10Hz. Those strings are what Ag Leader systems need to be able to to see speed and position.
Are you seeing speed on the runscreen? As well in the VT screen? If you are not seeing it on the VT screen, you will need to go into the speed settings and make sure that it's set to ISO GBSD. This will read GPS from the display through ISO. If it's already set to that, go into the VT settings and make sure that GPS speed is being broadcast. There are 2 signals that it can broadcast but you want to make sure that "Broadcast Display Speed (ISO GBSD)" is checked. | |
