roaming | alex2929 - 5/6/2019 09:32
I have loaded prescriptions on a pro 700 in the case format and in the shape file format twice. When i go to Data Management/Delete and select grower/farm/field, the prescriptions are listed to delete. However, when I go to the RX setup and select Grower/farm/field, their are no prescriptions listed to select. Any idea what i could have mixed up here?
You can't assign a prescription to a control channel until you have set up that channel correctly, including Product Setup (Toolbox > Product) and Work Condition Setup (Work Condition > Layer). Did you do both of these? |
