Alberta | If you have an ezboom, I got rid of my sprayer rate controller, the ezguide and ez boom will control your pressures and rates. Also, instead of paying 500 bucks for a trimble cable to control ur booms, I made my own using 2 relays for each boom valve and a days work and figuring and soldering wires. The melroe boom valves are reverse polarity, versus sending power to open or no power to close, they send power one way to open and the other way to close. If you can figure that out using relays, you can save yourself a $500 cable. | |
