Posted 4/14/2019 22:07 (#7439952) Subject: jd 8130 autosteer problem
i have a 8130 that throws a code:523826.10 when the steering wheel is quickly moved after starting ( since that times the steering column sensor the wheel sensor and the wheel wiring harness has been replaced also when trying to calibrate the wheel sensor the sensor conflict code is thrown any thought will be helpful
