| My 2 cents: If you are looking at the Iowa RTN, I hope you are close to one of the base stations (and hope they never take it down). The EZ500 requires CMR packets for RTK correction, and the only stream you can currently use is CMR Near or basically the closest base that the state has to you, which is currently a single base solution (not network solution). If it is over 8 miles you will not get repeatable sub inch accuracy, along with your issues of cell reception. | |
