Posted 3/23/2019 07:56 (#7396570 - in reply to #7396384) Subject: RE: Trimble fault 182 on JD8335RT HELP!!!!!!!!!!!
NW Ohio
That is the same issue we had with ours. Trimble will tell you to check voltage etc, then you replace the turn sensor and still have the same issue. Just take the NAV only back to version 11.XX
