Hagen Brothers farms,Goodrich ND | farmerbroun - 3/15/2019 22:28
Will have to see if new alternator spades are labeled. I put the tab toward front of tractor. Gauge was charging slightly after starting tractor. About two minutes later alt was a smokin. Guessing the tab needs to be reversed. I was told new alt had two spades on the back. It has three on the side. Technically I guess it does have two. :(
Tab to the front is correct for that delco alt. Wires are IG on nipo = #1 on delco.
#2 on delco = S on nipo alternator.
Your plug is on correct, almost certainly what is smoking your alternator is that you did not fully charge the battery before starting the new alternator.
Edited by Jon Hagen 3/16/2019 02:09
