Search Forums | Classifieds (217) | Skins | Language
Raven/Kinze Viper 4 question
Amc4life
Posted 3/14/2019 16:26 (#7380507 - in reply to #7379827)
Subject: RE: Raven/Kinze Viper 4 question
Butterfield, MN
It would be pretty straight forward to swap out the SmarTrax to a 3D node, assuming the hydraulics are new enough. Can you see which version is on the controller? It usually will should a version number on the home screen, like V4.0 or something like that. If it's at least 4.0, you should have no issues using an adapter cable and swapping over to the 3D node. If it's earlier than that, it could be more tricky.
