Missouri river bottom south of Sioux City, IA | The coverage maps are ESRI .shp files so most any mapping program should be able to load them in. I use HGIS or SMS. To test this out I would create a coverage map on your FMD or EZ-500 and then import it into your mapping software. Create some polygons in that imported coverage shp file and then save it. Transfer the file back onto the FMD data card or into the EZ-500. Make sure you place it in the farm/field/event that it was created in. You should see the newly created coverage areas after you bring up the same farm/field /event.
Tom N. |
