Missouri | The current sensors will not show any singulation data. With the current system, you could add a PMM (planter monitor module) and have normal population monitoring, or you could convert to DJ or DJ compatible sensors, add a STMM (seed tube monitor module) and have population monitoring and "advanced seed monitoring". Ag Leader can work with any seed sensor, as long as the appropriate module is chosen. 20/20 can only work with DJ sensors.
I like the idea of advanced seed monitoring, but it has long been a peeve of mine that to get it, one must change to a sensor that is overall less accurate.
I have a customer that is trying wave vision sensors this year. These are a newer, more modern sensor than common DJ sensors, and I am hopeful they will deliver on their promised accuracy. If these do as promised, that will be outstanding, as it will then be possible to have advanced seed monitoring without sacrificing the accuracy advantage Kinze sensors have over DJ sensors.
