| Probably not.
You can search on here...that problem/question comes up once a month. Golfnut has the answer— ubiquity hardware to bridge an access point in the outbuilding to the WiFi router in the house.
If it’s a short enough distance a different router OR access point might reach by itself. I’ve had good luck with an ubiquity UAP AC LR access point. Needs a router to go with it. Using an ER-X, here.
Will reach my phone at the end of the driveway, back of barn & back of shed with doors open. Range is lower coming back to the house than when leaving. Assume that’s phone’s fault, turning down radio power when out of range. | |
