| i suggest you change the motor speed to auto high.
Your freeplay can be dealt with in the calibration process. Are you doing the calibration with the booms extended or folded in?
It's absolutely critical to have to work with the booms out so that you get the proper sttering response when doing your calibrations.
For your Hz setting ck unfder system status, some units were shipped out at 1Hz instead of 5 Hz, which provided a slow steering response.
Also verify the direction the connectors are pointing on the controller. I had one unit where the customer put in the wrong orientation and i Could not get it to stop weaving.
Just some things to look at | |
