Classifieds (227)
12000# winch load semi?
Machinery Talk
Alberta Cowman
2/14/2019 19:30 (#7321202 - in reply to #7321052)
RE: 12000# winch load semi?
Most winches are rated on the first layer drum pull. You loose mechanical advantage the further out on the drum you are.
A snatch block would double the force and depending on your cable length allow you to pull closer to the drum.
acwd45
: 2/14/2019 18:36
dolittle
: 2/14/2019 18:38
dolittle
: 2/14/2019 18:41
cutlass87400
: 2/14/2019 18:44
rkline
: 2/14/2019 18:45
hydro70guy
: 2/14/2019 18:50
Sodbustr
: 2/14/2019 18:50
SD-455
: 2/14/2019 19:22
Alberta Cowman
: 2/14/2019 19:30
GM Guy
: 2/14/2019 20:16
Plow79
: 2/14/2019 23:26
GM Guy
: 2/15/2019 10:34
PatCMO
: 2/14/2019 20:45
