Madison, GA | got a 2005 ford f350 from the utility company that has a dp hydraulic winch that quit working and is leaking oil when trying to engage. The Eaton motor is on the left side of the winch spool but most of the oil pours out on the right side of the spool, does that mean the motor leaks by the shaft and the oil runs through the center of the winch and leaks out the far side?
(dp winch (full).JPG)
Attachments ---------------- dp winch (full).JPG (64KB - 50 downloads)
