Eastern Shore of MD | The pickup line is o ring sealed correct? Could be an issue there too.
How many hrs on the tractor? Asking because it may be worth changing the pump if your going to pull that side plate off to check the sump tube etc. unless you find another obvious culprit like a split o ring or something.
There is a relief valve in that system too that should be checked. I can’t recall off the top of my head exactly where it’s located but I believe it can be externally checked. | |
