| Check around on your printer manufacturers web site to see if a different driver should be used. We had a HP printer at work that would just print OK with the normal driver, but when a PCL print driver was used, the printing was much better. I believe Word Perfect and QP are part of the same WordPerfect suite, so depending on the version, you might also want to check the web site for them to see if a different driver should be used. Last I used Word Perfect, it was part of the Corel package. | |
