Louisiana | Top line on the valve has pressure only when foot brake is applied. Line going to brass fitting only has pressure when yellow button is pushed in.
No restriction in this line. We replaced valve with the same that was there before."Looks like the one pictured in the Bendix service data page you sent"We traced line from brass fitting on valve to the firewall "marked with X at firewall" in picture. Don't see any valves or kinks from firewall to brass fitting on valve we replaced.When line to brass fitting is attached and trying ta apply park brake air is exhausting slow and can watch park brake slowly engaging. Don't hear quick release of air like it normally would. Thanks again for your help.
Edited by south 2/10/2019 10:47
(2-10 brake (full).JPG)
(brake firewall (full).JPG)
Attachments ---------------- 2-10 brake (full).JPG (47KB - 7 downloads) brake firewall (full).JPG (86KB - 7 downloads)
