Butterfield, MN | Yes you can. The thing to look out for is doubling up on your terrain compensation if you are running AutoSteer. You'd either need to disable it in the Deere receiver or on the Raven steering. Otherwise, find where the Raven system is getting GPS and unplug it, plug into the Deere GPS. Turn on GGA, VTG, and ZDA. All can be at 10 Hz, but ZDA can be much lower than that if you can set it individually. | |
