Ohio | Hi, i have a problem with an Autopilot on a 8310R JD tractor...
The tractor is AG Ready with a GS3 standart monitor, to start working with autopilot we had to buy an antenna, so we bought an SF6000 antenna and conected.
This is where our problems started first of all as you probably know yow have 15 hours of work then you have to activate SF1 . We activated SF1 but after 15 h ended in did't work anymore. Officials from JD sayd that we should upgrade the vtv(or somethink like this, i don't remember somethink with monitor) electronic unit, they gave us a firmware we made this upgrade and there appeared another problem when starting the ignition wait untill it loads and then start the tractor, monitor shows that there are no anntena connected, but when starting the engine without waiting the ignition wo load everithik works great. What could be the problem? Officials said that we have to change the monitor is that the only solution??? | |
