Posted 1/24/2019 09:48 (#7268752 - in reply to #7268468) Subject: RE: Raven node again?
Butterfield, MN
You may hear something. The way the board slides into the enclosure does leave a slight amount of play. They do stick padding in above the gyros to reduce this slight movement. You could always unscrew the screws holding the node together and carefully pull the board out to see if you have any "extra" parts.
