Somewhereville, Earth | I sell both
You need to look at the RAVEN RCM rate controller, setup as a sprayer, its simple, and ISOBUS, they load in Ag Leader VERSA/INTEGRA and Incommand displays unlocked to Isobus and Autoswath unlock, and the Raven CRx and Viper 4 display (not to mention CNH, JD, Trimble etc)
The cool thing about Isobus displays is it allows you to choose your own Display preference, ie if you want something big that with Ipad app for proof of placement the Incommand displays are perfect, if you want some thing small (a small display is all you can fit in the cab lol), and economical, the Raven CR-7 works really nice as a Isobus display and will do what you want
the new raven CRx displays I don't think support the old rate controllers (i don't know there is none around me), but they will use the existing valves
you will need a unlock in the raven if you are doing a multiple product variable rate application
the other interesting fact is the RCM will store multiple profiles, it may work out nice to have one RCM and use it to control your spreader and sprayer, just have wiring harnesses on each machine and shift the RCM (depends on your situation)
Edited by pudding 1/28/2019 18:43
